Sinumerik Alarm 14155 Channel %1 block %2 invalid base frame definition for tool carrier offset
If a tool carrier selection causes a change in the table offset, a valid base frame must be defined in order to store this offset; for more information see machine data 20184 (TOCARR_BASE_FRAME_NUMBER).
Change the NC program or machine data 20184 (TOCARR_BASE_FRAME_NUMBER).
