Sinumerik Alarm 14165 Channel %1 block %2 active T number does not match selected tool
When an H or D number is programmed in ISO_2 mode, the T number used in the definition for this tool is determined. This number must be identical to the T number programmed explicitly.
– Local alarm reaction.
Change machine data $MC_TOOL_CORR_MODE or the part program.
