Sinumerik Alarm 14198 Channel %1 block %2 illegal change of tool direction with tool offset
If an offset is active in the tool direction, block change is not possible if this would change the assignment of the offset axes to the channel axes (plane change, tool change, cutter turning tool, geometry axis replacement).
– Local alarm reaction.
• Modify part program.
• Reduce the offset in tool direction to zero.
