Sinumerik Alarm 14270 Channel %1 block %2 pole programmed incorrectly
When defining the pole, an axis was programmed that does not belong to the selected processing level. Programming in polar coordinates always refers to the plane activated with G17 to G19. This also applies to the definition of a new pole with G110, G111 or G112.
Correct the NC part program. Only the two geometry axes may be programmed that establish the current machining plane.
