Sinumerik Alarm 14280 Channel %1 block %2 polar coordinates programmed incorrectly
The end point of the displayed block has been programmed both in the polar coordinate system (with AP=…, RP=…) and in the Cartesian coordinate system (axis addresses X, Y,…).
Correct the NC part program – the axis motion may be specified in one coordinate system only.
