Sinumerik Alarm 14290 Channel %1 block %2 poly nominal degree greater than 5 programmed for poly nominal interpolation
A poly nominal degree greater than five was programmed for the poly nominal interpolation. You can only program polynomials up to the 5th degree.
Modify part program.
