Sinumerik Alarm 14300 Channel %1 block %2 overlaid handwheel motion activated incorrectly
Handwheel override has been called up incorrectly:
• 1. For positioning axes:
• Handwheel override programmed for indexing axes,
• No position programmed,
• FA and FDA programmed for the same axis in the block.
• 2. For contouring axes:
• G60 not active,
• 1. 1st G group incorrect (only G01 to CIP).
Modify part program.
