Sinumerik Alarm 14400 Channel %1 block %2 tool radius compensation active at transformation switchover
A change of transformation is not allowed when tool radius compensation is active.
Perform tool radius compensation in the NC part program with G40 (in a block with G00 or G01) before performing a transformation change.
