Sinumerik Alarm 14403 Channel %1 block %2 preprocessing and main run might not be synchronized
Positioning axis runs cannot be accurately calculated beforehand. Consequently, the position in the MCS is not known exactly. It might therefore be possible that a change in the multiple significance of the transformation has been performed in the main run although no provision was made for this in the preprocessing run.
Modify part program. Synchronize preprocessing run and main run.
