Sinumerik Alarm 14510 Channel %1 block %2 PROC instruction missing on subroutine call
In subroutine calls with parameter transfer (“call-by-value” or “call-by-reference”) the called subroutine must begin with a PROC statement.
Define the subroutine in accordance with the type used.
1. Conventional subroutine structure (without parameter transfer):% SPF 123456
M17
2. Subroutine structure with keyword and subroutine name (without parameter transfer):PROC UPNAME
M17 ENDPROC
3. Subroutine structure with keyword and subroutine name (with parameter transfer “call-by-value”):
PROC UPNAME (VARNAME1, VARNAME2, …)
M17 ENDPROC
4. Subroutine structure with keyword and subroutine name (with parameter transfer “callby-reference”):
PROC UPNAME (Typ1 VARNAME1, Typ2 VARNAME2, …)
M17 ENDPROC
