Sinumerik Alarm 14530 Channel %1 block %2 EXTERN and PROC instruction do not correspond
Subroutines with parameter transfer must be known before they are called in the program. If the subroutines are always available (fixed cycles) the control establishes the call interfaces at the time of system power-up. Otherwise an EXTERN statement must be programmed in the calling program. Example:
N123 EXTERN UPNAME (TYP1, TYP2, TYP3, …).The type of the variable must match the type given in the definition (PROC statements) or it must be compatible with it. The name can be different.
Check the variable types in the EXTERN and the PROC statements for correspondence and correctness.
