Sinumerik Alarm 14600 Channel %1 block %2 reload buffer %3 cannot be established
%3 = File name
The download buffer for “execute from external” could not be created. Possible causes:
• Not enough memory available (for minimum see MD $MN_MM_EXT_PROG_BUFFER_SIZE)
• No resources available for MMC NCK communication (see MD $MN_MM_EXT_PROG_NUM)
• The file already exists
• Release memory, e.g. by deleting part programs
• Modify MD $MN_MM_EXT_PROG_BUFFER_SIZE and/or $MN_MM_EXT_PROG_NUM.
