Sinumerik Alarm 14610 Channel %1 block %2 compensation block not possible
An alarm was output which could be eliminated basically via program correction. Since the error occurred in a program which is processed from external, a compensation block/ program correction is not possible.
• Abort program with reset.
• Correct program on MMC or PC.
• Restart reloading (possibly with block search and interrupt location).
