Sinumerik Alarm 14660 Channel %1 block %2 SETINT instruction with invalid priority
The NCK input number must lie between 1 and 8. It is assigned a priority from 0 to 128 (1 is the highest priority) in the SETINT instruction with the keyword PRIO = … .Example: If NCK input 5 changes to “1” the subroutine LIFT_Z should be started with the highest priority. N100 SETINT (5) PRIO = 1 LIFT_Z
Program the priority of the NCK input with a value of not less than 1 or greater than 128.
