Sinumerik Alarm 14720 Channel %1 block %2 axes for centerless transformation not available
In the channel not all of the axes/spindles are available that have been defined in machine data for centerless grinding.
1. Modify part program.
2. Modify machine data:
24110 TRAFO_AXES_IN_n
21522 TRACLG_GRINDSPI_NR
21524 TRACLG_CTRLSPI_NR.
