Sinumerik Alarm 14740 Channel %1 block %2 no tool data available for centerless grinding
For centerless grinding, the tool data must be contained in T1, D1 (grinding wheel) or T2,D1 (regulating wheel). An error has been found here.
• Modify part program.
• Check tool data.
• Check machine data.
