Sinumerik Alarm 14750 Channel %1 block %2 too many auxiliary functions programmed
More than 10 auxiliary functions have been programmed in an NC block.
Check whether all auxiliary functions are necessary in one block – modal functions need not be repeated. Create separate auxiliary function block or divide the auxiliary functions over several blocks.
