Sinumerik Alarm 14759 Channel %1 block %2 motion synchronous action and wrong axis type
When there are several feeds, a spark-out time, or a retraction stroke for path motions, at least one GEO axis must be programmed. If the block also contains synchronous axes and there are several feeds, the feedrate for the synchronous axes is matched implicitly. No retraction stroke takes place for synchronous axes. However, after retraction stroke or spark-out time, the distance-to-go is also deleted in the block for the synchronous axes. The alarm is no longer used on P3.2.
Program the axis as positioning axis with axial feed, return stroke or spark-out time.
