Sinumerik Alarm 14761 Channel %1 block %2 motion synchronous action: DELDTG function not allowed with active tool radius compensation
Rapid delete distance-to-go for synchronous actions is not allowed with DELDTG when tool radius compensation is active.
• Deactivate tool radius compensation before performing rapid delete distance-to-go and then reselect or
• as of SW 4.3: “Delete distance-to-go without preparation”.
