Sinumerik Alarm 14762 Channel %1 block %2 too many PLC variables programmed
The number of programmed PLC variables auxiliary functions has exceeded the maxi- mum permissible number. The number is set in MD 28150 $MC_MM_NUM_VDIVAR_ELEMENTS.
Modify part program or machine data.
