Sinumerik Alarm 14763 Channel %1 block %2 too many link variables programmed
The number of NCU link variables programmed exceeds the maximum limit. The number is defined in MD $MC_MM_NUM_LINKVAR_ELEMENTS.
Modify part program or machine data.
