Sinumerik Alarm 14810 Channel %1 block %2 negative axis speed programmed for positioning axis %3
%3 = Axis
A negative feed (FA value) has been programmed for the displayed axis presently operating as a positioning axis. The positioning velocity may be programmed in the range 0.001 to 999 999.999 [mm/min, deg/min] for the metric input system and 0.000 1 to 39 999.999 9 [inch/min, inch/rev] for the inch input system.
Program the positioning velocity within the limits given above.
