Sinumerik Alarm 14811 Channel %1 block %2 incorrect value range for acceleration of axis/spindle %3
%3 = Axis, spindle
A value outside of the permissible input range of the programmed acceleration has been used. Values of between 1 and 200 % are possible.
Adjust the value range in accordance with the Programming Guide. Values of 1 … 200% are allowed.
