Sinumerik Alarm 14812 Channel %1 block %2 SOFTA not available for axis %3
%3 = Axis
SOFT is to be set as type of motion control for an axis. This is not possible because a bent acceleration characteristic has been selected for this axis via machine data.
Modify part program or machine data.
