Sinumerik Alarm 14821 Channel %1 block %2 error in selection or deselection of GWPS
On selecting grinding wheel surface speed programming with GWPSON, one of the following errors occurred:
• An attempt has been made to select the GWPS programming for a spindle that has already been assigned to another tool by TMON, GWPSON, CLGON or activation of the tool length compensation.
• Selection does not refer to a grinding-specific tool (400-499).
• An attempt has been made to select GWPS for the active tool although the TLC is not switched on.
• Selection refers to an invalid spindle number.
• A grinding wheel radius equal to zero was specified. On deselecting grinding wheel surface speed programming with GWPSOFF, one of the following errors occurred:
• Deselection does not refer to a grinding-specific tool (400-499).
• An attempt has been made to deselect GWPS for the active tool although the tool length compensation has not been activated.
• Check GWPSON and GWPSOF command.
• Check tool compensation data:
$TC_DP1 : 400 – 499;
$TC_TGP1: Spindle number.
