Sinumerik Alarm 14900 Channel %1 block %2 center point and end point programmed simultaneously
When programming a circle by means of the opening angle, the circle center point was programmed together with the circle end point. This is too much information for the circle. Only one of the two points is allowed.
Select the programming variant guaranteeing that the dimensions are definitely taken
over from the workpiece drawing (avoidance of calculation errors).
