Sinumerik Alarm 14910 Channel %1 block %2 invalid angle of aperture for programmed circle
When programming a circle by means of the opening angle, a negative opening angle or an opening angle greater than or equal to 360 degrees has been programmed.
Program opening angle within the allowed range of values between 0.0001 and 359.9999 [degrees].
