Sinumerik Alarm 15000 Channel %1 block %2 channel-sync instruction using illegal mark
A WAITM/WAITMC/SETM/CLEARM instruction was programmed with a marker number that was less than 1 or greater (MAXNUM_MARKER * MAXNUM_CHANNELS).
Exception: CLEARM(0) is allowed and clears all markers in channel!
Correct the instruction accordingly.
Clear alarm with NC START or RESET key and continue the program
