Sinumerik Alarm 15030 Channel %1 block %2 different measurement system settings
The INCH or METRIC instruction describes the system of measurement in which the data blocks have been read from the control. In order to prevent the incorrect interpretation of data intended for a particular system of measurement, a data block is only accepted if the above instruction matches the active system of measurement.
Change the system of measurement or load a data block which matches the system of measurement.
