Sinumerik Alarm 15165 Channel %1 block %2 error when translating or interpreting PLC Asup %3
%3 = String
At part program start, the data part of the selected PLC Asup is conditioned. If an error occurs (translator or interpreter) first this alarm is output and then a translator or interpreter alarm that describes the error in more detail. The error causes the interpreter to stop. Correction block is not possible.
Modify part program.
