Sinumerik Alarm 15395 Channel %1 master-slave not executable during block search
A master-slave coupling is to be closed in the part program via the instruction MASLON. The position offset $P_SEARCH_MASLD, however, cannot be correctly calculated during block search, as the axes to be coupled are located in different channels.
Make sure that all relevant axes are in the same channel.
