Sinumerik Alarm 15410 Channel %1 block %2 initialization file contains invalid M function
The only M function allowed in an Init block is the M02, M17 or M30 end-of-program function.
Remove all M functions from the Init block except for the end identifier. An Init block may contain value assignments only (and global data definitions if they are not defined again in a program that can be executed later) but no motion or synchronous actions.
