Sinumerik Alarm 15460 Channel %1 block %2 syntax error with modal function
The addresses programmed in the block are not compatible with the modal syntax-deter- mining G function. Example: N100 G01 … I .. J.. K.. LF
Correct the displayed block and ensure that the G functions and addresses in the block are in agreement.
