Sinumerik Alarm 15500 Channel %1 block %2 illegal angle of shear
The function CSHEAR has been called with an illegal (impossible) angle of shear, e.g. when the sum of angles between the axis vectors is greater than 360 degrees.
Program the angle of shear in accordance with the geometrical conditions of the machine and workpiece system.
