Sinumerik Alarm 15700 Channel %1 block %2 illegal cycle alarm number %3
%3 = Cycle alarm number
A SETAL command has been programmed with a cycle alarm number less than 60 000 or greater than 67 999.Alarm reactions of Siemens standard cycles: Nos. 61,000 -61,999: Interpreter stop; delete with Reset Nos. 62 000 – 62 999: Compensation block; delete with NC Start
Program alarm number in the SETAL instruction in the correct range.
