Sinumerik Alarm 15910 Channel %1 block %2 touch probe not allowed
Measure without deletion of distance-to-go In the part program, an illegal probe has been programmed with the command MEAW (measure without distance-to-go). The probe numbers 0 … no probe 1 … probe 1 2 … probe 2 are allowed, whether the probe is actually connected or not. Example: N10 MEAW=2 G01 X100 Y200 Z300 F1000 Probe 2 without deletion of distance-to-go
Include a probe number within the limits given above in the keyword MEAW=… This must correspond to the hardware connection of the probe.
