Sinumerik Alarm 15950 Channel %1 block %2 no traverse motion programmed
Measure with deletion of distance-to-go In the part program, no axis or a traversing path of zero has been programmed with the command MEAS (measure with deletion of distance-to-go).
Correct the part program and add the axis address or the traversing path to the measurements block.
