Sinumerik Alarm 15960 Channel %1 block %2 no traverse motion programmed
Measure without deletion of distance-to-go In the part program, no axis or a traversing path of zero has been programmed with the command MEAW (measure without deletion of distance-to-go).
Correct the part program and add the axis address or the traversing path to the measurements block.
