Sinumerik Alarm 16016 Channel %1 block %2 no retraction position programmed for axis %3
%3 = Axis name
The retraction enable was programmed for LIFTFAST without defining a retraction position for the axis. The retraction movement is no longer clear.
Program a retraction position for the relevant axis.
