Sinumerik Alarm 16100 Channel %1 block %2 spindle %3 not available in the channel
%3 = String
Mistake in programming: This channel does not recognize the spindle number. The alarm can occur together with a dwell or SPI function.
Please inform the authorized personnel/service department. Check the part program to determine whether the programmed spindle number is correct and whether the program is run in the correct channel. Check MD 35000 SPIND_ASSIGN_TO MACHAX for all machine axes to see whether one of them contains the programmed spindle number. This machine axis number must be entered in a channel axis of the channel-specific machine data 20070 AXCONF_MACHAX_USED.
