Sinumerik Alarm 16105 Channel %1 block %2 spindle %3 cannot be assigned
%3 = String
Mistake in programming: The programmed spindle is not assigned a real axis by the spindle number converter. The alarm can be issued after improper use of $SC_SPIND_ASSIGN_TAB[].
Correct setting data or modify part program.
