Sinumerik Alarm 16300 Channel %1 block %2 denominator polynominal with zero places within parameter range not allowed
The programmed denominator polynomial (with PL [ ] = … , i.e. without specification of geometry axis) has a zero place within the defined parameter range (PL = …). This means that the quotient of the numerator polynomial and the denominator polynomial is infinite or indeterminate.
Modify the polynomial block so that there is no zero place within the polynomial length in the denominator polynomial.
