Sinumerik Alarm 16400 Channel %1 block %2 positioning axis %3 cannot participate in spline
An axis assigned to a spline grouping (n) with SPLINEPATH (n, AX1, AX2, …) has been programmed as positioning axis with POS or POSA.
Do not assign the positioning axis to the spline grouping.
