Sinumerik Alarm 16500 Channel %1 block %2 chamfer or rounding negative
A negative chamfer or rounding has been programmed under the keywords CHF= …, RND=… or RNDM=…
Values for chamfers, roundings and modal roundings must be programmed with positive values only.
