Sinumerik Alarm 16730 Channel %1 block %2 axis %3 wrong parameter
In G33 (tapping with constant lead) the lead parameter was not assigned to the axis that determines the velocity. For longitudinal and face threads, the thread lead for the specified geometry axis must be programmed under the associated interpolation parameter. X -> I Y -> J Z -> K For taper threads, the address I, J, K depends on the axis with the longer path (thread length). A 2nd lead for the other axis is, however, not specified.
Assign lead parameters to the axis that determines the velocity.
