Sinumerik Alarm 16763 Channel %1 block %2 axis %3 programmed speed is illegal (zero or negative)
A spindle speed (S value) was programmed with the value zero or with a negative value.
The programmed spindle speed (S value) must be positive. Depending on the application case, the value zero can be accepted (e.g. G25 S0).
