Sinumerik Alarm 16779 Channel %1 block %2 coupling: too many couplings for axis %3, see active leading axis %4
%4 = Axis name, spindle number
More leading axes and spindles were defined for the specified axis/spindle than are allowed. The last parameter to be specified is a leading value object/leading axis to which the specified axis/spindle is already linked.
Modify part program.
