Sinumerik Alarm 16789 Channel %1 block %2 multiple link
A coupling has been switched on in which the axes/spindles have already been assigned by another coupling. Parallel couplings cannot be processed.
– Alarm display. – Interface signals are set. – Correction block is reorganized.
Check in the part program whether another link already exists for the axes.
