Sinumerik Alarm 16793 Channel %1 block %2 coupling of axis %3 prohibits transformation change
The specified axis is a slave axis in a transformation grouping. When the coupling is switched on, the transformation cannot be changed to another one.
Modify part program. Switch off coupling(s) of this axis before changing transformation or do not change the transformation.
