Sinumerik Alarm 16799 Channel %1 block %2 axis %3 is master axis and prohibits axis container rotation
The programmed axis/spindle is active as a master axis/spindle in a coupling. When the coupling is active, the axis container cannot be rotated.
Modify part program. Deactivate the coupling(s) for this axis/spindle before rotating the axis container or execute the axis container rotation at a later time.
